Removing data from a door schedule
BMitchell-ARoush
Message 1 of 8
BMitchell-ARoush
How do I remove data from a door schedule?  I have a shell and fit-out set that I am working on.  Both have been created as seperate projects in project navigator.  I have xrefed the shell base into the fit-out base and I need to remove the shell door references from the door schedule.
Any suggestions.
Replies (7)
Message 2 of 8
dbroad
Use uniformat classifications to filter the exterior doors out or in depending on your schedule.
Steps:
1)Import the uniformat classifications
2)Change the door styles to add the classifications.
3)Change the schedules to filter for classifications.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 8
leothebuilder
You can also filter your door schedule by layers........
Message 4 of 8
VitalyF
Applies To: for Schedule Table Style
do not specify the Door, it seems easier?
Message 5 of 8
BMitchell-ARoush
Could you explain the process a little?  I am not familiar with customizing schedules.
Message 6 of 8
VitalyF
Message 7 of 8
David_W_Koch
If you choose to go the Classification route, you may find these Help articles (and the additional articles to which they link) of use:
About Classification Definitions
To Filter Scheduled Objects by Classification in a Schedule Table Style
In addition to Doug Broad's suggestion to use the Uniformat Classification Definition (which ships with the program), you could create your own Classification Definition with just the classifications you need for this task.  For example, on a previous project, we needed separate Door Schedules for a building shell package and an interior package, and there were existing-to-remain doors that were not to appear in either.  I created a Classification Definition to allow for each door to be classified as Shell, Interior or NoSchedule, and then two separate Schedule Table Styles were created, one having the Shell Classification set on the Applies To tab, and the other having the Interior classification set.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 8 of 8
BMitchell-ARoush
Thanks for the help all.  In the end we inserted the door and space schedules on the x-ref and only selected those doors or spaces that were part of that file.
