Converting Polyface mesh to a polyline contour
Hi everyone,
I am working on a drawing with polyface meshes and I need to extract the contour of each as a polyline.
A sample file is attached.
Does anyone know how to do it?
Any help would be very much appreciated!
Calvino
regisrohde
http://forums.autodesk.com/t5/autocad-2004-2005-2006/convert-from-polyface-mesh-to-polyline/td-p/193...
If anyone has come across the issue above. Try the following:-
Try hatching the Polyface Mesh area with a non-solid hatch.
1. Type hatch and select the Polyface Mesh outline
2. Choose a non-solid hatch - Apply/OK
3. Delete the Polyface Mesh outline
4. Type hatchedit and select the hatch
5. Choose re-create boundary - OK.
Please mark this as the solution if it resolves your issue.Kudos gladly accepted.
Regis Rohde
