AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Missing callouts/annotations in Paperspace in ACA2008
3 REPLIES 3
2512 Views, 3 Replies
This is a problem that keeps popping up in new drawings and is driving me crazy!
Items like Building Section symbols and door & window symbols show in model space but not in paperspace.
Yes, all of the layers are set to display (thawed and on) in all viewports.
Drawings that were created in earlier versions do not have this problem.  I've tried copying the display sets from older drawings to the new drawings and there is no change to the problem.
Any help would be much appreciated.
3 REPLIES 3
Sounds like you are using Annotative Tags that are not showing for the scale of the Paper Space Viewport.  From your Model Space, change the scale to the same as the Paper Space viewport, see if the tags disappear.
in reply to: ToanDN
Thank you!  It wasn't exactly what helped me figure out the issue but it gave me a place to start.
adithgp1
In your paper space, switch on "Show annotation object - Always". It will be found on the bottom right alongside line weight button.
Forma Design Contest
