Quick Properties
Quick Properties
heather_o
Quick Properties
heather_o
I am using 2019
My computer recently took a turn and I had to reinstall AutoCAD from scratch.  I've gotten most of my settings back to how I like them, but I can't figure out how to get my Quick Properties back.  I know QPMODE and its variable, but I don't want QP popping up all the time.  If I double clicked on a line, for example, my quick properties dialog box would then pop up.  What is the setting for QP to pop up only with a double click?
pendean
Community Legend
Community Legend
@heather_o wrote:
...What is the setting for QP to pop up only with a double click?
Not sure what you are asking for has ever been an option OOTB, did you by chance customize double-click actions in CUI command in your old setup to only bring up QuickProperties?
Then you need to do that again.
Double-clicking can activate a command depending on the object type, that's the default action. Does that look strange to you this time around too?
heather_o
I thought about that too, but it didn't sound familiar.  I went to look into that and couldn't figure out how to do it, so I know that's not what I did.
I do miss that feature, didn't know how much I used it.
pendean
Community Legend
Community Legend
That setting already exists for LINE objects, perhaps you're not double-clicking on LINEs? CUI command
heather_o
I didn't have LINE under double click actions.  I just added it and now it works.  You are amazing!  Thank you!!
