Load theme settings name from a list definition
Richard.Vivanco
Advisor Advisor
Message 1 of 9
Richard.Vivanco
Hi, i created a list definition with several names that i need for my project (bathroom, kitchen, dinner room, deposit, laundry etc)
I use this list  to assign a name to my spaces, i make this in the properties panel
My question is: its possible to load my list definition to assign the names in the Display Theme?  Right now i create one by one the same name that appears in my list definition, so i think its inefficient workflow.
Any ideas please?
Richard Vivanco V.
Arq. BIM Manager + Autodesk Certified Instructor
Youtube | LinkedIn
autodesk 3DS pro
Replies (8)
Message 2 of 9
brian_adams
in my opinion it not possible
Message 3 of 9
Richard.Vivanco
Bad news...   if im not in a mistake, this workflow its possible in revit.  You create rooms, change the names, and then in the legend colors appears these names.
Maybe my AA workflow is not correct.
Richard Vivanco V.
Youtube | LinkedIn
autodesk 3DS pro
Message 4 of 9
No, your workflow is correct. Just a limitation of the way themes in ACA work.
  • Would like to see the ACA Theme auto-populate like Revit does.
  • Would like Revit's themes to be applicable to any object type(not just rooms/spaces)/property like ACA's are.
Different platforms, different capabilities, One day...
Message 5 of 9
ACA/AMEP Zones are more akin to the room key in Revit graphically. Might be worth a look, but the workflow is still Edit Zone Template > Apply to spaces rather than dynamic from the space properties
Message 6 of 9
Richard.Vivanco
Thanks for the response, i will test it.
Richard Vivanco V.
Youtube | LinkedIn
autodesk 3DS pro
Message 7 of 9
brian_adams
And it works good.! I use it this way...but the only problam is to make the exhaustive list of all posible rooms
Message 8 of 9
dbroad
This response is a possible partial workaround to the problem.
In the displaytheme style command, open the Display Theme Styles (Imperial) drawing.  Note the number of saved display theme styles.  Pick one (commercial, educational, medical, or residential). Then duplicate, and put your names in it.  Import the display theme style and save the display themes styles drawing. Not as automatic as importing an existing list but better than working from scratch.
Architect, Registered NC, VA, SC, & GA.
Message 9 of 9
Richard.Vivanco
Sounds good...i can use this in a template too
I will try.
Richard Vivanco V.
Youtube | LinkedIn
autodesk 3DS pro
