AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Latest Updates | New Knowledge Network Solutions | AutoCAD Architecture
2 REPLIES 2
matthew.d
1479 Views, 2 Replies
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated regarding AutoCAD Architecture?
 Subscribe to receive updates for new Knowledge Network articles on AutoCAD Architecture.
For more updated solutions, also check out the AutodeskHelp Blog!
2016 Solutions
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
2 REPLIES 2
matthew.d
in reply to: matthew.d
October 2018
Cursor and commands lagging in AutoCAD Architecture
AEC Dimensions are not displayed correctly after copying them to a different drawing in AutoCAD Arch...
Swings of certain doors from tool palette (D A CH) don’t react to the opening value in AutoCAD Archi...
Objects are not displayed as defined with the Style Manager in AutoCAD Architecture/MEP
Editing project properties freezes AutoCAD Architecture/MEP
How to add property set data to schedule tables in AutoCAD Architecture
September 2018
Larger file size PDFs being created from AutoCAD Architecture compared to AutoCAD
Architectural objects not visible in a 3D view in AutoCAD Architecture
Unable to retrieve AutoCAD Architecture license from Network License
August 2018
Slow performance while opening and saving file with AEC Objects in AutoCAD
Round columns display with facets in most display configurations in AutoCAD Architecture or AutoCAD ...
Error: “Data from this cell comes from an automatic source” is shown when AutoCAD Architecture calcu...
How to create a double-height space without duplicating walls in multiple Constructs in AutoCAD Arch...
July 2018
IFC export gives incorrect results
Crash or hang when doing “Add to Tool Palette” in AutoCAD Architecture or AutoCAD MEP 2019
December 2017
AutoCAD 2013 crashes when launching on Windows 10
November 2017
AutoCAD Architecture: Cannot redefine multi view blocks
AutoCAD Architecture: How to change zone colour when switching between display configurations
AutoCAD Architecture: IFC export interrupts without any error message
Display theme displays the same color for different spaces in AutoCAD Architecture
October 2017
AutoCAD Architecture: Bluebeam add on still being loaded after removing the trail
AutoCAD Architecture: Muntins are displayed incorrect when switching between display representations
AutoCAD Architecture: Roof area calculation
AutoCAD Architecture: Wall styles do not display hatch at a certain length
Crashing drawing walls in AutoCAD MEP
Error AecDACHBaseDB.dbx loading a file
September 2017
AutoCAD Architecture 2018: AUTOSNAP is set to 32 after installing Update 2018.1.1
AutoCAD Architecture: Is it possible to combine spaces for room calculations
AutoCAD Architecture: DWG to PDF.pc3 does not plot transparency
Schedule tags in display measurement units incorrectly in AutoCAD Architecture or AutoCAD MEP
Where are custom paths stored in the STYLESBROWSER in AutoCAD Architecture or AutoCAD MEP
Doors and windows will not insert into two walls that are side by side in AutoCAD Architecture
AutoCAD Architecture 2018 installation fails with connection error.
August 2017
How to copy tool palettes from one machine to the next in AutoCAD Architecture
Reset to default and migrate settings utilities missing from AutoCAD
Viewport layers do not stay frozen in 2018 with MVBlocks in AutoCAD MEP
Printing AutoCAD MEP or Architecture objects from Model Space with Realistic shademode does not plot...
AutoCAD Architecture 2018: How to use Live Maps in Architecture
Doors do not offset from wall end when inserted in AutoCAD Architecture
“New View Drawing” and “Existing View Drawing” options greyed out in AutoCAD Architecture or AutoCAD...
Cannot divide spaces in AutoCAD Architecture
Regenerate View tool removes xref attachments in AutoCAD Architecture
Error: “A Style or Definition could not be located for this tool.” in AutoCAD Architecture or AutoCA...
Realistic visual style displays incorrectly in AutoCAD Architecture or AutoCAD MEP
Some walls don’t clean up properly when placed in certain areas of a drawing in AutoCAD Architecture
July 2017
AutoCAD Architecture 2018: Spiral stairs are incomplete in 2D sections.
AutoCAD Architecture/MEP: AEC Objects not showing in previous versions of AutoCAD
June 2017
Creating, editing or updating 2D Sections in AutoCAD Architecture or AutoCAD MEP is very slow or doe...
AutoCAD Architecture/MEP: DWG 2018 file format is missing in the application menu when exporting a d...
AutoCAD Architecture/MEP: New feature commands from AutoCAD are not available in the user interface
May 2017
AutoCAD 2017 Update 1 Doesn’t Update the Ribbon on AutoCAD Verticals
AutoCAD Architecture 2018 on Mac
Backwards compatibility of AEC elements is lost in AutoCAD Architecture 2018 or AutoCAD MEP 2018
Cannot insert content from Content Browser in AutoCAD Architecture or AutoCAD MEP on a Surfacebook
Dimensions round off in length fields in Schedules in AutoCAD Architecture or AutoCAD MEP
How to create a variable width column in a schedule table in AutoCAD Architecture
Manage Content Library button does not display dialog when selected in the STYLESBROWSER in AutoCAD ...
April 2017
“Last Edited By” field in Project Navigator lists the wrong user in AutoCAD Architecture or AutoCAD ...
Centerlines panel missing from Annote ribbon tab in AutoCAD Architecture or AutoCAD MEP
Drawing1 not created at launch in addition to start tab in AutoCAD Architecture or AutoCAD MEP
Block Editor ribbon tab missing in AutoCAD Architecture or AutoCAD MEP
Schedule table values display in metric instead of imperial units in AutoCAD Architecture or AutoCAD...
Styles don’t update in the styles browser in AutoCAD Architecture or AutoCAD MEP
March 2017
Cannot find and install the Detail Component/Keynote Database Migration Utility for AutoCAD Architec...
How to create a roof slab with a curved overhang in AutoCAD Architecture
System requirements for AutoCAD Architecture 2018
Autodesk Architectural Desktop 3.3 crashes while launching on Windows XP
February 2017
Some objects do not display when inserted from Content Browser into AutoCAD Architecture or AutoCAD ...
Can AutoCAD Architecture install AutoCAD patches
AutoCAD Architecture: Frequent display problems towards the end of the day in busy times
AutoCAD Architecture: Hidden lines on the drawing after creating a bent section
How to create a roof shape that slopes between 3 or more differing corner heights in AutoCAD Archite...
January 2017
Matt DiMichele
diana.yr
Technology Administrators
