Announcements
Latest Updates | New Knowledge Network Articles | AutoCAD Architecture
Azmeera.M
Azmeera.M
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for AutoCAD Architecture?
(List shown in chronological order)
 Subscribe to receive updates for new AutoCAD Architecture Knowledge Network articles.
For more updated solutions, also check out the AutodeskHelp Blog!
Azmeera M.
Autodesk Employee
Azmeera.M
ARCHIVE
January 2016
Solid fill hatch does not display in 2D sections and elevations in AutoCAD Architecture
Room name in tag justified left instead of center in AutoCAD Architecture
February 2016
Custom CUI menus do not stay loaded
DWG drawings exported from Inventor are not printed in black
Dynamic block lookup not returning correct parameters
Field object doesn´t read project information in AutoCAD Architecture
How to display paper size on sheet in AutoCAD Architecture
How to export AutoCAD drawings to SAP2000
How to set a default SAVE / OPEN folder
How to use annotative text and dimensions in AutoCAD
Not all drawings of a selected folder are visible in the Sheet Set Manager
Portions of AEC walls in XREFs disappear in AutoCAD Architecture
Refreshing project in AutoCAD Architecture
Unable to edit drawing view using Model documentation in AutoCAD
March 2016
AutoCAD Architecture 2016: Extracting MSP files from Service Pack 1
How to set up demolition and revision Views in AutoCAD Architecture or AutoCAD MEP
Some content folders missing in AutoCAD Architecture or AutoCAD MEP
April 2016
AutoCAD Architecture model is displayed sectioned in Navisworks
Exporting DWG to IFC not showing objects properly
Cannot add a new sheet to a sheet set in AutoCAD Architecture
Scheduling data from multiple xrefs in AutoCAD MEP or AutoCAD Architecture
May 2016
Trim/Split mass elements feature does not work in non-default UCS
June 2016
AutoCAD Architecture freezes when opening certain drawing files
DACH EXTENSIONS 2017 for AutoCAD Architecture 2017 and AutoCAD MEP 201
July 2016
Schedule table is not showing volume of mass element
August 2016
AutoCAD Architecture 2017 with Open Light 2017 installed crashes
September 2016
Exporting CADmep properties from AutoCAD Architecture
Failed to locate property set file
Vault Data Standard and AutoCAD Architecture
Azmeera M.
Autodesk Employee
