AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
I cannot create new projects with the Project Navigator in AutoCAD Architecture 2025
10 REPLIES 10
Message 1 of 11
mikeshick
696 Views, 10 Replies
mikeshick
When I try, on 3 different computers, I get the same result:
I cannot make a new project in navigator of AutoCAD Architecture 2025. When trying, I get failure 1) to create project, and 2) to rename project and directory.  I get the following error messages
Mike Shick
www.medesigns.us
Mike Shick
www.medesigns.us
10 REPLIES 10
Message 2 of 11
yanhan.lim
in reply to: mikeshick
yanhan.lim
Hi @mikeshick ,
Thanks for posting your issue onto the AutoCAD Architecture forum. In my testing thus far, I am able to create a project, rename and repath.
Could you share anymore details of anything you think is useful to know? e.g. AutoCAD Architecture installation method, Windows version, other products installed.
Does this occur in a specific folder that you are trying to create your project or in all paths?
Lastly, if you have not done so already, could you try saving your project onto a pathway that is on your local desktop and see if that works.
Best regards,
Yanhan
Yanhan Lim
QA Analyst
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Hi @mikeshick ,
Best regards,
Yanhan
Yanhan Lim
QA Analyst
Message 3 of 11
pendean
pendean
Community Legend
Community Legend
@mikeshick have you had a chance to reset one of those three ACA2025 seats back to defaults, restart that PC, avoid any profile import or other migrations from older or other seats or much of anything else, then trying again?
Message 4 of 11
mikeshick
in reply to: pendean
mikeshick
Yes...I tried and got the same results.
If if create the project on my c drive, I don't have a problem.
I've been creating my projects on a drive that syncs with Dropbox for about 4 years without issue.   It appears the problem comes from trying to create the project file in a folder that is sync'd with Dropbox.
Mike Shick
www.medesigns.us
Mike Shick
www.medesigns.us
Message 5 of 11
pendean
pendean
Community Legend
Community Legend
@mikeshick wrote:
...If if create the project on my c drive, I don't have a problem.
...It appears the problem comes from trying to create the project file in a folder that is sync'd with Dropbox.
Perhaps the syncing process is the trigger for the initial fail: easy to test out.
I believe Autodesk recommends the higher-cost DROPBOX BUSINESS accounts over the free consumer version: open a support ticket and find out.
Message 6 of 11
mikeshick
mikeshick
I have the Dropbox for business.  The problem is definitely with the "Updated" Project Navigator working with the Dropbox.  As said, I haven't had any of the issues in 4+ years of using DB.  It only started with the updated 2025.
Mike Shick
www.medesigns.us
Mike Shick
www.medesigns.us
Message 7 of 11
pendean
pendean
Community Legend
Community Legend
@mikeshick wrote:
...It only started with the updated 2025.
Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Message 8 of 11
mikeshick
mikeshick
Yes...I have an open case already. Thanks.
Mike Shick
www.medesigns.us
Mike Shick
www.medesigns.us
Message 9 of 11
mikeshick
mikeshick
Updating the software with the latest patch resolved the issue.  Didn't realize I hadn't installed the patches yet.  🙂
thanks for your help.
Mike Shick
www.medesigns.us
Mike Shick
www.medesigns.us
Message 10 of 11
yanhan.lim
yanhan.lim
Hi @mikeshick ,
Glad to hear it working again with the latest patch and thank you for furnishing us with more details of your workflows.
I would like to clarify your earlier message when you mentioned "It only started with the updated 2025".
I assume you were implying that the new AutoCAD Architecture 2025 version had the issue, and that your problem got resolved when you installed the the AutoCAD 2025.0.1 Update (you can find the 'about information' of your product from the drop down menu found on the top righthand side)
Best regards,
Yanhan
Yanhan Lim
QA Analyst
Hi @mikeshick ,
Best regards,
Yanhan
Yanhan Lim
QA Analyst
Message 11 of 11
mikeshick
in reply to: yanhan.lim
mikeshick
Yes, that is correct @yanhan.lim
Thanks.
Mike Shick
www.medesigns.us
Thanks.
Mike Shick
www.medesigns.us
