I repeat my question if anyone can help me that would be great
how to create labels that detect the definition of each object created
I don't know the creation protocol well and can't find the "variable" keywords that must be placed in the label so that it displays what we want from the set definitions
when you edit a multi-view block, place a new attribute then a field, the list does not display the actual setdefinitions for the objects
Solved by didman78. Go to Solution.
If you are trying to create a Schedule Tag that will display the value of a Property in a Property Set that is attached to an object or, for AEC Objects, it Style or Definition, you need a Multi-View Block that has a View Block (vanilla AutoCAD Block Definition) that includes an Attribute Definition whose Tag name is formatted like this:
PROPERTYSETNAME:PROPERTYNAME
For example, looking at the out-of-the-box Room Tag in AutoCAD Architecture 2025, the AEC8_Room_Tag Multi-View Block Definition has a View Block called Aec8_Room_Tag_Basic_P.
Placing an instance of that View Block and exploding it reveals that it has two attribute definitions, one whose tag is SPACEOBJECTS:NAME and another whose tag is SPACEOBJECTS:NUMBER.
The SPACEOBJECTS:NAME attribute displays the value of the Name property in the SpaceObjects Property Set, and the SPACEOBJECTS:NUMBER attribute displays the value of the Number property in the SpaceObjects Property Set.
The easiest way to create a new Schedule Tag is to use the _AecDefineTag command, which can be found in two places:
This blog article explains how to use that command.
