How to intersect two gable roofs
CA-DESIGNSNC7SU
Observer Observer
CA-DESIGNSNC7SU
Observer
Observer
I've been trying to intersect two gable roof in AutoCAD Architecture 2023 without success. Does anyone knows how to do that, by the way, we call "California Roof" to  that kind of roof setting, just in case; any help will be much appreciated.
Thank you
Gepaha
R_Tweed
Hi and Welcome,
Was the link from @Gepaha helpful?   I've attached a dwg file that has a few other methods that might be useful as well.  Below is a list of edits in the attached dwg.
  1. Trim roof object(s) and place together.
  2. Make a mass element infill.
  3. Use model explorer  ans grouped elements.
  4. Edit points on one or multiple roofs to make each transition.
  5. Convert to roof slabs, trim etc.
 All of these can then be extracted into a horizontal section and or elevations and sections.
CA-DESIGNSNC7SU
Observer
Observer
Thanks a lot, I haven't had a chance to work back on the roof I wanted to intersect; I have to go through your blog and your videos; you got a lot of helpful information.
Thanks again!
CA-DESIGNSNC7SU
Observer
Observer
Thanks a lot for taking the time to create the CAD file, its very helpful, I might need to learn a little more about the "roof objects".
On the other hand , I haven't had a chance to work back on the roof I wanted to intersect; I think I will have to go through "@gphanauer" blog and some of his videos; looks like he got a lot of helpful information.
Thanks again!
