- Mute
- Permalink
- Report
So I set up some palettes to do details. I put some hatch on a hatch palette with like concrete, site work, stone wall, gravel, etc. I right click on the palette tool and set the properties to make the hatch go in on the layer I want. It will work for awhile. I think where it goes wrong is when I match properties with another hatch. After that it changes the layer in the HPDLGMODE panel to whatever I match properties too. So after that every hatch come in on that matched layer no matter what the palette hatch layer is set to. What I have to do is turn on the HPDLGMODE (because I have it off normally) set the layer hatch will go in on back to Current ( see pic where it changes in blue circle), then hatch something to get the setting to stick, then delete that hatch. After all that nonsense I can use my palette hatches again and they go in on the correct layers until I match properties with hatch.
Is there some setting to avoid this? The blue circled always changes from current to whatever I match.
Nick DiPietro
Cad Manager/Monkey
