PDF displays pixelated lines at angles
Hi.
I have been working on some plans that have lines in angles(No octoganal ) and when I print the plans as a pdf the lines get pixel it...
However, if i make straight lines and print them they look good but when I rotate it them in Photoshop they get pixel it again
Plsss help me
@Anonymous for clarity VStudley edited the original subject: Pixel lines
pendean
Community Legend
Community Legend
Sounds like your PDF viewer's display settings need to be fixed: what are you using?
Idk to be honest😣
Idk if the problem is that I took the plan from rhino and fix it in cad
dbroad
Post a sample drawing (with just the important objects) and the resulting pdf along with a markup describing your complaint in the pdf.
Architect, Registered NC, VA, SC, & GA.
Victoria.Studley
Hi @Anonymous,
I'm checking in to see if you need more help with this issue. Will you be able to post a sample file where the issue is happening? Did any of the suggestions here help?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
