AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Drawing scales in Metric vs Imperial
7 REPLIES 7
Message 1 of 8
PaulSinnott1828
103822 Views, 7 Replies
What are the common architectural drawing scales in Metric vss Imperial for documenting plans ( Imperial 1/4"/3/8"/1/2"=1'-0") ,elevations ,section and detail drawings.
7 REPLIES 7
Message 2 of 8
pendean
in reply to: PaulSinnott1828
Depends: what region if the works do you work in and what does your client expect?
Message 3 of 8
Relating common ARCHITECTURAL metric scales to English counterparts.
METRIC        CLOSEST IMPERIAL SCALE
1:5m
1 cm = 5 cm
                                       3" = 1'-0"
                                       three inch scale
1:50
1 cm = 0.5 m
                                      1" = 4'
                                      quarter inch scale
                                      (actual scale: 1" = 4.17')
1:100
1 cm = 1 m
                                       1" = 8'
                                       eighth inch scale
                                       (actual scale: 1"= 8.33')
1:200
1 cm = 2 m
                                      1" = 1/16'
                                      sixteenth inch scale
                                      (actual scale: 1" = 16.66')
1:500
1 cm = 5 m
                                       1" = 40'
                                       (actual scale: 1" = 41.66")
1:1000
1 cm = 10 m
                                       1" = 80'
                                       (actual scale: 1" = 83.34')
1:5000
1 cm = 50 m
                                       1" = 400'
                                       (actual scale: 1" = 418.66')
1:10000
1 cm = 100 m
                                       1" = 800'
                                       (actual scale: 1" = 833.32')
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 4 of 8
Libbya
in reply to: steve216586
While your math is (mostly) correct, the convention with Imperial architectural scales is X = 1'-0", not 1" = X.  In other words, 1/4" = 1'-0", not 1"=4'.  Also, for the scale of 1"=1/16' I think you meant to say 1"=16 (which should really be 1/16" = 1'-0").
Message 5 of 8
steve216586
in reply to: Libbya
Tell this group how poor their math is: http://www.dbarchitect.com/words/writings/105/Metric%20Scales.html
I was only tryinng to help the OP by passing on info I found on the web. I do see the typo (maybe) with the 1" = 1/16'. It should only be 16' not 1/16'.
Reguardless, for someone using metric scales, the format given is correct. There are 48 increments of 1" in 4' which equals 48 increments of 1/4" in 1'.
Message 6 of 8
Libbya
Your post gives me the impression that you believe I was trying to be hurtful rather than helpful.  That was not and is not the case.
Message 7 of 8
steve216586
in reply to: Libbya
Not at all. It wasn't my information; that is all I was saying. I can see where it is derived though and didn't question it coming from a multi-award winning architectural firm.
I can also understand why they may use the 1" = X format for metric users. Most Europeans have difficulty with our fractional inches when they are accustomed to a base of 10..
Message 8 of 8
On the Metric side I'd put 1:10 instead of 1:5, which in my experience in the UK is a far more common detail scale
I'd add 1:20, which is another detail scale
I'd definitely add 1:1250 and 1:2500 is are the two most common scales for location plans (OS Data tends to be printed at 1:1250 for example).
dJE
Forma Design Contest
AutoCAD Beta
