What are the common architectural drawing scales in Metric vss Imperial for documenting plans ( Imperial 1/4"/3/8"/1/2"=1'-0") ,elevations ,section and detail drawings.
Solved by steve216586. Go to Solution.
Relating common ARCHITECTURAL metric scales to English counterparts.
METRIC CLOSEST IMPERIAL SCALE
1:5m 1 cm = 5 cm | 3" = 1'-0" three inch scale
1:50 | 1" = 4' |
1:100 |
1" = 8'
1:200 |
1" = 1/16'
1:500 |
1" = 40'
1:1000 |
1" = 80'
1:5000 |
1" = 400'
1:10000 | 1" = 800' (actual scale: 1" = 833.32') |
1:50 | 1" = 4' |
1:100 |
1" = 8'
1:200 |
1" = 1/16'
1:500 |
1" = 40'
1:1000 |
1" = 80'
1:5000 |
1" = 400'
While your math is (mostly) correct, the convention with Imperial architectural scales is X = 1'-0", not 1" = X. In other words, 1/4" = 1'-0", not 1"=4'. Also, for the scale of 1"=1/16' I think you meant to say 1"=16 (which should really be 1/16" = 1'-0").
Tell this group how poor their math is: http://www.dbarchitect.com/words/writings/105/Metric%20Scales.html
I was only tryinng to help the OP by passing on info I found on the web. I do see the typo (maybe) with the 1" = 1/16'. It should only be 16' not 1/16'.
Reguardless, for someone using metric scales, the format given is correct. There are 48 increments of 1" in 4' which equals 48 increments of 1/4" in 1'.
Your post gives me the impression that you believe I was trying to be hurtful rather than helpful. That was not and is not the case.
Not at all. It wasn't my information; that is all I was saying. I can see where it is derived though and didn't question it coming from a multi-award winning architectural firm.
I can also understand why they may use the 1" = X format for metric users. Most Europeans have difficulty with our fractional inches when they are accustomed to a base of 10..
On the Metric side I'd put 1:10 instead of 1:5, which in my experience in the UK is a far more common detail scale
I'd add 1:20, which is another detail scale
I'd definitely add 1:1250 and 1:2500 is are the two most common scales for location plans (OS Data tends to be printed at 1:1250 for example).
dJE
dJE
