AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
draw wall on top of other
1 REPLY 1
cadomatic
165 Views, 1 Reply
hi
the blue wall in the pic is 100cm,
i want to draw another wall on top of it,
how can i do it?
Shay
1 REPLY 1
David_W_Koch
in reply to: cadomatic
That will depend on how you want your cleanups to work.
You could set the current elevation to 100 cm and activate the Replace Z Value with Current Elevation tool.  That would put the baseline of the new Walls at +100 cm.
You could draw the new Walls with the baseline at 0 cm and then edit the Floor Line so that all vertices are 100 cm above the baseline.
You could duplicate your Wall Style and set the bottom of all components at 100 cm above the baseline.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Forma Design Contest
AutoCAD Beta
