AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
cut plan difficulty
1 REPLY 1
redsge
252 Views, 1 Reply
cut plan difficulty
If someone could clarify -
   I am having trouble slecting my cut planes to remove visibilty of lower portions or upper portions ov wall plans.  I have already created cut plans set to my first floor, and to my second floor construct at the elevations that I desire, but I cannot remedy how to remove visually the "ghost walls" that appear below or above my cut planes.  Is this a setup issue with my display representations, or am I wrongly configuring my cut planes?  It seems as though I had this ability in 2011, and since upgrading to 2012, I do not have it.  What is going on?
Regards
1 REPLY 1
ntellery
in reply to: redsge
are you using a different template with different display reps?
Using Project Navigator?
Prob easiest to post a stripped down file and someone can examine it.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
Forma Design Contest
AutoCAD Beta
