AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Board and Batten hatch pattern not working
6 REPLIES 6
tevansERD
1364 Views, 6 Replies
i created this board and batten hatch pattern but it is not working. it has a 5 1/2" batten every 24" O.C.
*BoardandBatten24in,Board_Batten_1x6_Batten
90, 0, 0, 24, 24, 24
90, 5.5, 0, 24, 24, 24
6 REPLIES 6
pendean
in reply to: tevansERD
How does it not work exactly? Post a screenshot.
tevansERD
in reply to: pendean
the battens are 5 1/2" but 12" oc and not 24"
pendean
And if you double the spacing in the code (since it is half that now) you get... ?
tevansERD
It breaks the code
hugha
Try:
90, 0, 0, 0, 24
90, 5.5, 0, 0, 24
hth
Hugh
www.hatchkit.com.au
hugha
in reply to: hugha
Just to amplify - every unbroken pattern line is specified by 5 items:
angle, origin X, origin Y, slew, spacing
it's somewhat easier to specify the items in a reverse order
5.  Spacing between instances of this line (here 24)
4.   Slew (ignored, normally zero)
2,3  any point on the line. (here:  0, 0 or 5.5, 0)
1.  finally line angle from the X axis (90)
Slew comes into play when broken lines are being specified along with their draw/skip intervals.
Too late to fix now but reversing spacing and slew within the original prescription would have removed an unnecessary item from unbroken line definition. 🙂
Hugh Adamson
www.hatchkit.com.au
