Autodesk Content Browser 2017
When I try to access the content browser the following error occurs "The catalog you specified could not be found". Please also find attached a print screen with the error.
Thank you in advanced!
pendean
Community Legend
Community Legend
You are not running plain AutoCAD 2017, this forum, are you?
I suspect this solution also applies to you https://forums.autodesk.com/t5/autocad-architecture-forum/content-browser-missing-in-2017/m-p/626451...
leothebuilder
Did you create or "publish" your own tool catalog?
The screen shot seems to indicate that and there must be something wrong with the way you specified the location when you created the catalog.
It's difficult to figure out how this happened and suggestion would be to start again and CAREFULLY follow all the prompts...
I've created my own catalog by mistake. Would it be useful to reinstall AutoCad Architecture?
Thank you!
Thank you! I've solved the issue by following this steps http://blogs.rand.com/support/2013/06/acaamep-autodesk-content-browser-is-empty.html
