AutoCAD
AutoCAD
AutoCAD
Olá comprei um notebook e estou tentando instalar o autoCAD.
Já é a quinta vez que tento instalar, mas ele acaba parando na metade da instalacão.
Aparece uma falha é não consigo saber porque da isso.
Alguem poderia me ajudar?
David_W_Koch
By what means are you trying to install AutoCAD?  If you are installing from your Autodesk Account page, using the "Install Now" or "Browser Download" methods, you may find that the installation runs better if you use the Virtual Agent to download all of the installation files first, and then run the installation from the downloaded files, rather than downloading the installation files at the same time as the installation is proceeding.
Since you have already had one or more failed installations, the first step will be to do a clean uninstallation, so that there is no interference from any files left behind by the previous attempts.  If you have the Autodesk uninstall tool available (Start > All Programs > Autodesk, then scroll to see if you got far enough in the installation to have the uninstall tool).  That tool is pretty good at removing a specific version of a program completely, and it will warn you if you try to uninstall something that some other Autodesk software that you are not uninstalling needs.  If you do not have that, then this Autodesk Knowledge Network article explains how to do a clean uninstallation.
With a clean machine ready for a new installation, you can download the required files from the Autodesk Virtual Agent.  Select Download links, and then use the links to find your software and the specific version you want to install.  Depending upon the version, there may more than one ZIP file to download.  Download all of them (one at a time) to the same folder.  When are are there, double click on the "001" file to start the extraction process.  The files from all of the ZIP files will be extracted to the folder of your choice; the default will be a subfolder under C:\Autodesk.  When the extraction is complete, an installation window will open, and you can begin the installation then, if desired.  If you would prefer to start the installation at a later time, you can cancel and then, when you are ready, you can double click on the Setup.exe file in the subfolder for that product.
Traduzido pelo Google Tradutor:
Por que meios você está tentando instalar o AutoCAD? Se você estiver instalando a partir da sua página da Autodesk Account, usando os métodos "Instalar Agora" ou "Download do Navegador", você pode achar que a instalação corre melhor se você usar o Agente Virtual para fazer o download de todos os arquivos de instalação primeiro e depois executar o Instalação dos arquivos baixados, em vez de fazer o download dos arquivos de instalação ao mesmo tempo em que a instalação está sendo realizada.
Uma vez que você já teve uma ou mais instalações com falha, o primeiro passo será fazer uma desinstalação limpa, para que não haja interferência de quaisquer arquivos deixados para trás pelas tentativas anteriores. Se você tiver a ferramenta de desinstalação do Autodesk disponível (Iniciar> Todos os Programas> Autodesk, então role para ver se você tem o suficiente na instalação para ter a ferramenta de desinstalação). Essa ferramenta é muito boa em remover uma versão específica de um programa completamente, e irá avisá-lo se você tentar desinstalar algo que algum outro software Autodesk que você não está desinstalando necessidades. Se você não tiver isso, este artigo da Autodesk Knowledge Network explica como fazer uma desinstalação limpa.
Com uma máquina limpa pronta para uma nova instalação, você pode baixar os arquivos necessários do Autodesk Virtual Agent. Selecione Links de download e, em seguida, use os links para encontrar o software ea versão específica que deseja instalar. Dependendo da versão, pode haver mais de um arquivo ZIP para download. Baixe todos eles (um de cada vez) na mesma pasta. Quando estiverem lá, clique duas vezes no arquivo "001" para iniciar o processo de extração. Os arquivos de todos os arquivos ZIP serão extraídos para a pasta de sua escolha; O padrão será uma subpasta em C: \ Autodesk. Quando a extração estiver concluída, uma janela de instalação será aberta, e você pode começar a instalação então, se desejado. Se preferir iniciar a instalação mais tarde, pode cancelar e, quando estiver pronto, pode fazer duplo clique no ficheiro Setup.exe na subpasta desse produto.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
