AutoCAD Architecture - Terrain from coords in TXT file?
Hi all,
is there any possibility to make a surface (terrain) from coordinates stored in TXT file? I changed Archicad to Autodesk Autocad Architecture and it is impossible to make terrain from text file.
Can you be so kind and help me with this, please?
Thankx.
Victoria.Studley
Hi @Anonymous,
First, welcome to the Autodesk Community, and thanks for posting your question here in the AutoCAD Architecture forum!
While it's easier for a program like AutoCAD Civil 3D to handle coordinates from a text file, there are a couple of options in the core AutoCAD program (as well as AutoCAD Architecture). Take a look at the following resource, and let me know if it helps:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
