AutoCAD Architecture - Terrain from coords in TXT file?
Message 1 of 9
Hi all,
is there any possibility to make a surface (terrain) from coordinates stored in TXT file? I changed Archicad to Autodesk Autocad Architecture and it is impossible to make terrain from text file.
Can you be so kind and help me with this, please?
Thankx.
Replies (8)
Message 2 of 9
gotphish001
I don't have an answer for you sadly, but you might want to ask in the autocad architecture forums instead to get a better chance of getting a solution. Forum goers will be much more versed on what ACA is capable of over there.
https://forums.autodesk.com/t5/autocad-architecture-forum/bd-p/248
On a side note I've just begun trying to learn archicad. Was what you are asking possible in archicad? Just curious. The work flow seems so much more logical in archicad. I'm quickly becoming a fan.
Nick DiPietro
Cad Manager/Monkey
Message 3 of 9
Thank you! My mistake. But you are right. Archicad is much more easier. But I knew AutoCAD... so I hoped that it will be the same. Nice and smooth. But it does not. Unfortunately so complicated.
Message 4 of 9
imadHabash
If i understand you right you may create a script file from your coordinates and run it through autocad with SCR command. >> Click <<
Imad Habash
Message 5 of 9
Victoria.Studley
Hi @eee.sss,
It looks like you've posted this thread twice accidentally, so I'm posting my reply from the other thread here as well, so that you'll see it.
First, welcome to the Autodesk Community, and thanks for posting your question here in the AutoCAD Architecture forum!
While it's easier for a program like AutoCAD Civil 3D to handle coordinates from a text file, there are a couple of options in the core AutoCAD program (as well as AutoCAD Architecture). Take a look at the following resource, and let me know if it helps:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Message 6 of 9
Victoria.Studley
Hi @Anonymous,
I'm just checking in again to see if you need more help with this issue. Did the suggestions I or the other community members posted yesterday help you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Message 7 of 9
Thank you very much. I tried SCRipt. Without any success. With 3DPOLY it made something. Some multi direction line. But it is not 3D Mesh or 3D Surface. In Archicad: Two Clicks and Mesh is made. Autocad: Scripts and no Mesh 😞 Oh no. Please help.
Message 8 of 9
Victoria.Studley
Hi @Anonymous,
In order to get more advanced tools for importing your points and creating mesh topographies, you might need to use a different AutoCAD vertical (AutoCAD Civil 3D or AutoCAD Map 3D both have more robust features in this regard).
Victoria Studley
Message 9 of 9
OK. But... Is it possible to make some mesh, or surface, where you can change elevation of the points? Some net to make a 3D model. Simple one. 30 points for example... I am trying to find some tutorials... nothing similar.... Thanx.
