AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
autocad architecture 2017 runs for 30 seconds then pauses for 20 seconds.
4 REPLIES 4
371 Views, 4 Replies
I am using autocad architecture 2017.  for the last few weeks it will run for 30 seconds then pause for 20 seconds, repeat.  Any suggestions how to fix this?
Tags (1)
Labels (1)
4 REPLIES 4
pendean
What different with your computer or where you store files since the year 2016 when ACA2017 was new?
The software was installed on my current machine in August 2019.  I started working from home in March and the wifi here is very slow.  No changes to software or hardware since the initial install.
pendean
If you disconnect from the internet on that PC and work from files on your PC, does the slowness problem go away?
Seems to have worked. I need the wifi though to get emails. Is there any way to disconnect it just for autocad?
Forma Design Contest
