AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
ccamilalvarezz
333 Views, 2 Replies
SIGN
Hi! When I stand on any line a sign appears. I don´t know what it means and why it appears. I want to remove it. Does someone knows how? Thank you!
Labels (1)
2 REPLIES 2
pendean
in reply to: ccamilalvarezz
That symbol indicates that there is a constraint between those two lines, constraining the horizontal line to be perpendicular to the vertical line.
If you do not want that constraint to be applied, you can use the DELCON command, selecting all objects from which you wish to remove the constraints.
If you did not intend for there to be a constraint there, and do not want new constraints to be inferred as you add new objects, set CONSTRAINTINFER to 0.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Forma Design Contest
