Associating a section object with a named view not working. - AutoCAD Architecture 2026.0.1
varg.zaugg
Message 1 of 12
varg.zaugg
Trying to associate a saved model view with a section object is not possible in the selection of saved view
settings. It is always <None>. But it should, according to:
To Associate a Section Object with a Named View
@varg.zaugg Your post title was modified to add the product name and version and to increase findability - CGBenner
Replies (11)
Message 2 of 12
imadHabash
You can get it as shown in below image...
Imad Habash
Message 3 of 12
varg.zaugg
Please read my post.
No, I can't get it selected. This is why my post exists here and shows at the second screenshot, that it doesn't work.
Has anyone an idea why it doesn't work?
Message 4 of 12
ChicagoLooper
@varg.zaugg
Did you click OK?
Chicagolooper
Message 5 of 12
paullimapa
could you share this drawing here with this problem?
Paul Li
IT Specialist
@The Office
Message 6 of 12
imadHabash
If you get back to the link in your Original Post, you will find that all of your need exists in the first dialog (view manager).
Imad Habash
Message 7 of 12
varg.zaugg
The order to create/save a view first may be crucial, sure. But it doesn't work.
A short video:
Message 8 of 12
paullimapa
What AutoCAD version are you running?
Do you have the latest updates installed?
Enter About command do a screenshot and share this here.
Paul Li
IT Specialist
@The Office
Message 9 of 12
varg.zaugg
It tells me, this version here:
8.8.61.0 AutoCAD Architecture 2026.0.1
By the way, I encounterd this issue on another machine with ACA 2025...
Is there maybe a system variable setting to adjust?
Message 10 of 12
paullimapa
I’d suggest moderator to move this post to ACA forum for better feedback
Paul Li
IT Specialist
@The Office
Message 11 of 12
R_Tweed
In this example, I'm using ACA in paperspace. Click within a paperspace viewport and type view command. The view dialog box will appear and all options are available.
Message 12 of 12
varg.zaugg
I found out the error source: It works in AutoCAD Architecture "as AutoCAD".  But NOT in Autocad Architecture.
But why not in Autocad Architecture? Probably prorifle or dwt-setting?
I still assume a system variable value......
