Associating a section object with a named view not working. - AutoCAD Architecture 2026.0.1
varg.zaugg
Message 1 of 14
varg.zaugg
Trying to associate a saved model view with a section object is not possible in the selection of saved view
settings. It is always <None>. But it should, according to:
To Associate a Section Object with a Named View
@varg.zaugg Your topic title has been modified to include the Product and version and moved to the AutoCAD Architecture forum to increase findability - CGBenner
Replies (13)
Message 2 of 14
imadHabash
You can get it as shown in below image...
Imad Habash
Message 3 of 14
varg.zaugg
Please read my post.
No, I can't get it selected. This is why my post exists here and shows at the second screenshot, that it doesn't work.
Has anyone an idea why it doesn't work?
Message 4 of 14
ChicagoLooper
@varg.zaugg
Did you click OK?
Chicagolooper
Message 5 of 14
paullimapa
could you share this drawing here with this problem?
Paul Li
IT Specialist
@The Office
Message 6 of 14
imadHabash
If you get back to the link in your Original Post, you will find that all of your need exists in the first dialog (view manager).
Imad Habash
Message 7 of 14
varg.zaugg
The order to create/save a view first may be crucial, sure. But it doesn't work.
A short video:
Message 8 of 14
paullimapa
What AutoCAD version are you running?
Do you have the latest updates installed?
Enter About command do a screenshot and share this here.
Paul Li
IT Specialist
@The Office
Message 9 of 14
varg.zaugg
It tells me, this version here:
8.8.61.0 AutoCAD Architecture 2026.0.1
By the way, I encounterd this issue on another machine with ACA 2025...
Is there maybe a system variable setting to adjust?
Message 10 of 14
paullimapa
I’d suggest moderator to move this post to ACA forum for better feedback
Paul Li
IT Specialist
@The Office
Message 11 of 14
R_Tweed
In this example, I'm using ACA in paperspace. Click within a paperspace viewport and type view command. The view dialog box will appear and all options are available.
Message 12 of 14
varg.zaugg
I found out the error source: It works in AutoCAD Architecture "as AutoCAD".  But NOT in Autocad Architecture.
But why not in Autocad Architecture? Probably prorifle or dwt-setting?
I still assume a system variable value......
Message 13 of 14
CGBenner
@varg.zaugg
Hello, were you able to find any resolution to this question?
Chris Benner
Message 14 of 14
ChicagoLooper
@varg.zaugg wrote
<<…It works in AutoCAD Architecture "as AutoCAD".  But NOT in Autocad Architecture.>>
Are you using tour standard office template? If you are, then try again, still using AutoCAD Architecture, but this time use an OOTB template, not one with your firm’s logo, custom blocks, and customized settings.
When creating your firm’s official template, the author might have also created specific settings (established a Profile) so your drawing, and everyone else’s, complies with the office standard.
When using the as AutoCAD version where it works, it’s an indication you’re not using your firm’s standard (or Profile). Talk to the template’s creator to get a better understanding of your firm’s standard Profile.
Chicagolooper
