AutoCAD 2000/2000i/2002 Archive (Read Only)
Showing results forĀ
Did you mean:Ā
Import CGM files in Autocad 2000
9 REPLIES 9
Message 1 of 10
6320 Views, 9 Replies
I need to import some CGM files into autocad, somebody can help me please, I
have an urgent work to do and didnĀ“t find any trick in the web. Thanks a lot
in advance.
Patrick De Waegenaere
9 REPLIES 9
Message 2 of 10
Have you checked cgmlarson.com?
Message 3 of 10
Yes, doesnĀ“t have a program for that purpose. Thanks
"Matti Pitkanen" wrote in message
news:f096439.0@WebX.maYIadrTaRb...
Message 4 of 10
Patrick,
Most graphics programs, like Powerpoint, can import CGM. You could then copy and paste to ACAD.
Jesse
Message 5 of 10
Can I edit it after copy him from Power Point in
Autocad? Thanks
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Patrick,
Jesse
Message 6 of 10
Patrick,
Even easier, is simply to drag and drop the CGM fine into ACAD. As for editing, I'd recommend you edit the file with a program more compatable with CGM, before importing into AutoCAD.
Jesse
Message 7 of 10
Jesse, thanks for your help, but I need to edit it
in autocad for several reasons. There is too much datas in the CGM files, and I
need to edit them in an Autocad file. That s my big problem. There is other
reasons to do that. All I could do at the moment is import it but no chance to
edit it. Must be a trick for that. I don t believe that s
imposible.
Thanks again for your help.
Patrikc
Patrick,
Jesse
Message 8 of 10
Patrick,
Understand your problem, but it's kinda like Apples & Oranges, while you can put them in the same basket, they remain Apples & Oranges. Much more practical to do the editing in the appropiate program as some aspects of CGM would be lost if made editable in ACAD (shaded or colored fills for example). If you could send me a typical CGM file that you're trying to use, might be able to help more.
Jesse
Message 9 of 10
You buy this (no other choice):
http://www.cgmlarson.com/convert_cgm_image.html
Then you import the resulting file (TIFF, JPEG, GIF, PDF, CALS
Raster, PCX, PNG, Sun Raster, Windows BMP, XWD) into Adobe
Illustrator10 (you might have to buy that too from
http://www.adobe.com/products/illustrator/main.html) or a Raster
to Vector translator software (you might have to buy that too)
which translate a new file into DXF or DWG that you can then
import into AutoCAD.
Or, you import the resulting file into AutoCAD, and trace over
it.
Apples and Oranges, no matter which way you look at it šŸ˜‰
Enjoy.
Dean Saadallah
www.pendean.com
"Patrick De Waegenaere" wrote in message
news:A60212F6CFEADBE645A64B7C10EE066D@in.WebX.maYIadrTaRb...
me please, I
Thanks a lot
> in advance.
Message 10 of 10
I have your answer......I had a .cgm file from a
friend, brought it into MS Visio and then ungrouped it and then I can save as a
.dwg. It might not be perfect but send me a file and I will test it for
you.
Sean
it in autocad for several reasons. There is too much datas in the CGM files,
and I need to edit them in an Autocad file. That s my big problem. There is
other reasons to do that. All I could do at the moment is import it but no
chance to edit it. Must be a trick for that. I don t believe that s
imposible.
Patrikc
Patrick,
Jesse
