AutoCAD 2000/2000i/2002 Archive (Read Only)
Layer control in viewports?
3 REPLIES 3
248 Views, 3 Replies
Is there a way to freeze layer in mutible viewports at once.
I have about 8 viewports in each 6 layouts. I want to freeze the same layers in each viewport but I do not want to do it 42 different times. Is there a way I can select all the viewports an freeze the layers once? I tried saving state and restoring but it did not work.
3 REPLIES 3
If you FREEZE a layer it will be frozen in ALL viewports.
VPLAYER will help if you need to address the viewports individually or
as a group.
DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
I do not want the layers frozen in the model.
VPLAYER
And you can specify more than one layer to freeze at a time by putting
commas (e.g.: Layer1,Layer2,Layer3) with no spaces in between the layer
names and also the use of wildcards and/or creating a script (as this is
a command line command) to help automate the process.
If they are to be the same and you have the Bonus/Express Tool(s) LAYFRZ
and LMAN these might work for you.
Tracy Lincoln
