alguem sabe por que o programa apresenta uma mensagem que a licença esta fora do tempo? qual a soluçao?
Hi @Anonymous,
The issue can be caused by many things but the licensing component is always a good check,
If you go to task manager, then services, do you see Adsk Licensing Component? If so make sure it is running, if not right click and select start, if you don't see it at all then you can install from https://manage.autodesk.com/
Failing the above follow the steps here: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-License-checkout-timed-out-What-do-you-want-to-do-in-AutoCAD-2020.html
Google translate:
does anyone know why the program presents a message that the license is out of time? what's the solution?
Start here:
Olá @Anonymous
Olá...
Tente a solução apresentada no Link Abaixo:
Tempo de verificação de licença expirado
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
