What software are you using? Can you share a screenshot of your material nodes and the values for the SSS section in your surface shader
Are the normals pointing outwards? Does changing the SSS Radius/Scale help?
The normals were reversed and i'm using c4d...Read my reply to lee.
it seems like a normals problem, but is there any way I can reverse the normals within Arnold? because am using a plugin called Realflow for c4d...and the mesh it generates(uneditable) has inverse normals,if i make it editable then the simulation/animation will be gone.
What happens when you use Invert Normals in the Arnold Parameter Tag.
It doesn't work without me disabling double-sided.
In the Arnold Tag? Why is that a problem?
Yes it the Arnold tag, and I don't want to disable double-sided because tthe object is double sided
Pleasse i need an answer.
