Subsurface Scattering.
Message 1 of 11
sss for small objects are just black, why?
Replies (10)
Message 2 of 11
Here is a sample scene.
Message 3 of 11
ACCCC
What software are you using? Can you share a screenshot of your material nodes and the values for the SSS section in your surface shader
Message 4 of 11
lee_griggs
Are the normals pointing outwards? Does changing the SSS Radius/Scale help?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 5 of 11
The normals were reversed and i'm using c4d...Read my reply to lee.
Message 6 of 11
it seems like a normals problem, but is there any way I can reverse the normals within Arnold? because am using a plugin called Realflow for c4d...and the mesh it generates(uneditable) has inverse normals,if i make it editable then the simulation/animation will be gone.
Message 7 of 11
lee_griggs
What happens when you use Invert Normals in the Arnold Parameter Tag.
Lee Griggs
AUTODESK
Message 8 of 11
It doesn't work without me disabling double-sided.
Message 9 of 11
lee_griggs
In the Arnold Tag? Why is that a problem?
Lee Griggs
AUTODESK
Message 10 of 11
Yes it the Arnold tag, and I don't want to disable double-sided because tthe object is double sided
Message 11 of 11
Pleasse i need an answer.
