Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Look at wireframe shader.
Use facing ratio in the opacity(geometry) in standard surface shader, ( check the opaque is off)
Here is the Render From it
Yes, Facing Ratio is ideal for this. Examples at the bottom of these pages:
https://docs.arnoldrenderer.com/display/A5AFMUG/Facing+Ratio
https://docs.arnoldrenderer.com/display/a5AFHUG/Facing+Ratio
Hi!
Here my approach to this:
- create and aiStandardSurface an turn Base Weight & Specular Weight to 0
- set Transmission to 1 and Transmission Color to a light blue
- use the Transmission Depth to allow more light passing trough thicker objects
- turn on Thin Layer
- fake a Fresnel with a Ramp node in the Transmission Color
- to control how the transmission varies with the thickness of the geometry, add a remapValue node to the Transmission Weight
https://www.youtube.com/watch?v=glG4dUnSH3o&t=28s
