How can i make an Xray shader?
Message 1 of 8
Replies (7)
Message 2 of 8
hitecom8172
Look at wireframe shader.
Message 3 of 8
parabhdeep
Use facing ratio in the opacity(geometry) in standard surface shader, ( check the opaque is off)
Message 4 of 8
parabhdeep
Message 5 of 8
lee_griggs
Yes, Facing Ratio is ideal for this. Examples at the bottom of these pages:
https://docs.arnoldrenderer.com/display/A5AFMUG/Facing+Ratio
https://docs.arnoldrenderer.com/display/a5AFHUG/Facing+Ratio
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 6 of 8
I did it before posting the question..It didn't work because i forgot to switch on invert..Thanks everyone
Message 7 of 8
laomusic_arts
Hi!
Here my approach to this:
- create and aiStandardSurface an turn Base Weight & Specular Weight to 0
- set Transmission to 1 and Transmission Color to a light blue
- use the Transmission Depth to allow more light passing trough thicker objects
- turn on Thin Layer
- fake a Fresnel with a Ramp node in the Transmission Color
- to control how the transmission varies with the thickness of the geometry, add a remapValue node to the Transmission Weight
Message 8 of 8
lee_griggs
https://www.youtube.com/watch?v=glG4dUnSH3o&t=28s
Lee Griggs
AUTODESK
