Arnold - Cinema 4D starting up stop at 'loading plugins'
Message 1 of 11
I have tryout version of Arnold and the problem is that when Cinema 4D is starting up it stuck at 'loading plugins'. After uninstaling Arnold everything starts to work again. Any idea what can be the problem? I have crapy video GTX 560 Ti - maybe this?
Replies (10)
Message 2 of 11
Stephen.Blair
What version of CINEMA 4D? These are the minimum required versions:
  • CINEMA 4D R17.032 or above
  • CINEMA 4D R18.020 or above
  • CINEMA 4D R19.024 or above
// Stephen Blair
// Arnold Renderer Support
Message 3 of 11
Hey Stephen, I have Cinema 4D R18. Arnold version is also for R18.
Message 4 of 11
Stephen.Blair
What version of R18? You need to check the full version number. Is it R18.020 or later?
// Stephen Blair
Message 5 of 11
Version of Cinema 4D is R18.057. I have also bit old processor - 2Quad Q6600 2.4GHz.
Octane Demo is working here though...
Message 6 of 11
andrewvado
Community Visitor
Community Visitor
I am having the same problem too with Cinema 4D R19 and the latest version of Arnold for a iMac 4.2 GHz Intel Core i7 64 GB 2400 MHz DDR4 Radeon Pro 580 8192 MB. Was there a solution for this?
Message 7 of 11
Stephen.Blair
Do you have R19.024 or later?
Can you try running the CINEMA 4D commandline app? That should give us more error messages.
  • Open a Terminal
  • In the Terminal, run this command:
/Applications/MAXON/CINEMA\ 4D\ R19\Commandline.app/Contents/MacOS/Commandline
  • Then highlight everything output by Commandline, press CMD+C to copy it, and post it
// Stephen Blair
Message 8 of 11
andrewvado
Community Visitor
Community Visitor
I am working off R19.
Last login: Wed Oct 3 13:42:26 on ttys000
Dicadmins-iMac-2:~ dicstudent$ /Applications/MAXON/CINEMA\ 4D\ R19\Commandline.app/Contents/MacOS/Commandline
-bash: /Applications/MAXON/CINEMA 4D R19Commandline.app/Contents/MacOS/Commandline: No such file or directory
Message 9 of 11
Stephen.Blair
sorry, change the one / to \ in the command I pasted
// Stephen Blair
Message 10 of 11
Hermond_van_Peables
  • CPUs need to support the SSE4.1 instruction set
    Your CPU, the Q6600 does not have the 4.1 instruction set needed by Arnold, you need to update your CPU.
Message 11 of 11
Thank you man!
