Arnold 7.3.2.1 now available, with fixes for GPU rendering, Rocky Linux, and more
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
19 June 2024
This is a bug-fix release. For the full list of features in Arnold 7.3.2, see the Arnold 7.3.2.0 release notes.
Bug Fixes
ARNOLD-14365 - Fix AiNodeGetMatrix to return node matrix instead of identity after node initialization in batch renders
ARNOLD-14779 - AtProfiledLockable not compiling on Windows in newer MSVC due to Mutex::native_handle_type
ARNOLD-14893 - [GPU] 4MB GPU memory leak per frame
ARNOLD-15041 - Arnold does not run on Linux distros with glibc 2.39 (RHEL 9.4)
ARNOLD-15048 - Fix OIDN dll name clash with DCCs by renaming OIDN libraries
ARNOLD-15060 - Arnold should not catch C++ exceptions it did not generate
ARNOLD-15087 - uv_projection shader uses corrupt UVs for evaluating its default_color shader
ARNOLD-15121 - [GPU] crash when CUDA error has no message
ARNOLD-15122 - Crash destroying a light that is part of a light group
ARNOLD-15136 - Random hang when parallel initializing scene
ARNOLD-15169 - Crash when modifying a child node from procedural_update
usd#1923 - Fix instance primvar indices with multiple prototypes
usd#1929 - Ensure subdiv_iterations is not set unnecessarily during procedural updates
usd#1932 - Fix a crash when the number of elements in a primvar is not equal to the number of points
// Stephen Blair
// Arnold Renderer Support
