I hope this is the correct forum. I use Arnold by building a text "ass" file and specifying that to "kick.exe". I would like to specify the output driver to be Open EXR and also to set various parameters associated with EXR. All documentation I have found so far assumes one is using a front end like Maya or 3DS Max, but I am not. Does anyone know how to do this or point me to the relevant documentation?
Thank you,
MW
I guessed that if there was a "driver_tiff" command in the .ass files, that there would be a "driver_exr" as well. And there was although I am not sure that the file created was valid yet because I cant look at it.
This is disturbing because that means that what I have been using for .ass information is not comprehensive. Who do I talk to about this?
MW
Ha ha, the forum asks if I "accept the solution" that I myself provided. Well, uh, sortof, but no, I still need to know what the parameters are for the "driver_exr" tag.
You have to specify the outputs in the options node.
Each output has a driver and a filter (but all outputs could use the same, for example, for a merged exr).
The driver determines the output format.
