Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Height Map Problem behind Glass object.
26 REPLIES 26
Message 1 of 27
2510 Views, 26 Replies
I have a glass object with a height map plugged in displacement when I render the scene it's look fine but when I use another glass obj in front of it the render doesn't show the height data and the glass is rendered without it. What am I missing here?
Tags (3)
Labels (3)
26 REPLIES 26
Message 2 of 27
I uploaded the photos.
Message 3 of 27
lee_griggs
How high is your Specular Ray depth ? Do you have Caustics enabled and Opaque disabled for the glass object?
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 4 of 27
Specular Ray depth is 10 and Opaque is enabled for both glass and Caustics is enabled for the glass object without height map. Better quality with more ray but nothing fixed yet.
Message 5 of 27
And here without Caustics
Message 6 of 27
lee_griggs
Disable Opaque. It looks like there is something there. What does it look like with 5AA?
Lee Griggs
AUTODESK
Message 7 of 27
It has 5 AA and Opaque disabled for both glasses.
Message 8 of 27
joie
In my opinion, there are several ray depths and your specular one is OK. The problem could be the transparency one. Or you can just try to boost every rey depth and see what happens.
Message 9 of 27
It doesn't fix it even with 10 Specular and Transmission ray depth 😐
Message 10 of 27
Is any Solid Angle's staff here?
Message 11 of 27
maxtarpini
Probably but none have a magic wand 🙂 better you upload a scene that can reproduce your problem
Message 12 of 27
Just try it yourself. You will see there is problem with glasses.
Message 13 of 27
maxtarpini
there's no problem with displacement behind multiple transp/refr objects. that's why I'm suggesting you to upload a scene 🙂
Message 14 of 27
joie
As I said, the displacement is not your problem, your problem is that the surface doesn't reflect, so the problem should be in the ray depth limit. Did you notice that there is a kind of "total" depth limit?, so, even if you boost your specular and refraction ones, those obey the total limit also.
Message 15 of 27
Did you use glass shader for the object below the glass?
Message 16 of 27
What is your glass shader settings? @Max Tarpini
Message 17 of 27
The problem is not fixed by reducing the Ray Depth even with 50 20 20 rays still the same issue.
Message 18 of 27
Hi, Does it have thickness?
Message 19 of 27
here is the scene.zip I couldn't upload the displacement map it's more than 2MB so just add a checker and try it.
Message 20 of 27
teddude75
@Alireza Nateghi
light2_glass_main is not subdivided. Also vector space should be tangent. Try get the displacement to work with a grey shader before adding all those ray depth bounces.
TED
