I've read many versions of "make sure you're rendering to a batch instead of through the render view," which I am. The EXR files render and contain Cryptomatte passes, but they are all separated out into 4 channels per AOV.
For example: crypto_asset, crypto_asset0, crypto_asset01, crypto_asset02
instead of just crypto_asset
Then the mattes that come out of this are all wrong. Selecting a material creates a mask with many materials in it, etc.
I double checked and AOV's from Redshift come in as expected, only show the one name in the Nuke dropdown and selections work correctly.
I thought Fusion read them correctly, but it also does not produce correct mattes from them.
Any ideas? This is Latest Houdini and Arnold as of 3-21-20 and Nuke Studio 12.1v1, Cryptomatte v 1.2.6.
Attached is what the Crypto passes look like in the Nuke dropdown.
That's normal, you have to download cryptomatte for Nuke, to be able to use them
link here:
https://github.com/Psyop/Cryptomatte
like this:
work fine for me, here is the the hip file with : asset, material,abject and custom
HtoA_cryptomatte.zip
edit: try to download the latest cryptomatte for Nuke here:
Maybe you have to use Arnolds driver for writing files. It was the source of my problems. The documentation says it's required for Cryptomatte output.
See section "Arnold product type":
