Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
HtoA Cryptomatte Broken in Nuke
4 REPLIES 4
mgenehoffman
930 Views, 4 Replies
I've read many versions of "make sure you're rendering to a batch instead of through the render view," which I am. The EXR files render and contain Cryptomatte passes, but they are all separated out into 4 channels per AOV.
For example: crypto_asset, crypto_asset0, crypto_asset01, crypto_asset02
instead of just crypto_asset
Then the mattes that come out of this are all wrong. Selecting a material creates a mask with many materials in it, etc.
I double checked and AOV's from Redshift come in as expected, only show the one name in the Nuke dropdown and selections work correctly.
I thought Fusion read them correctly, but it also does not produce correct mattes from them.
Any ideas? This is Latest Houdini and Arnold as of 3-21-20 and Nuke Studio 12.1v1, Cryptomatte v 1.2.6.
Attached is what the Crypto passes look like in the Nuke dropdown.
Tags (1)
Labels (1)
4 REPLIES 4
in reply to: mgenehoffman
That's normal, you have to download cryptomatte for Nuke, to be able to use them
link here:
https://github.com/Psyop/Cryptomatte
like this:
mgenehoffman
I have the Cryptomatte gizmo, I've used it for years with other renderers. It's just the Arnold Houdini renders that don't produce correct mattes.
work fine for me, here is the the hip file with : asset, material,abject and custom
HtoA_cryptomatte.zip
edit: try to download the latest cryptomatte for Nuke here:
Maybe you have to use Arnolds driver for writing files. It was the source of my problems. The documentation says it's required for Cryptomatte output.
See section "Arnold product type":
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_houdini_solaris_ah_Arnold_Render_Settings_...
Technology Administrators
