Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Denoise aov's using oidn in solaris
8 REPLIES 8
Message 1 of 9
mattiasTQTV7
266 Views, 8 Replies
How do we go about denoising aovs in Solaris. Im using the default Arnold rendernode setup that creates an oidn shader in /materials/default_arnold_imager. In the Layers of that one I can see RGBA and its the only pass that is getting denoised. I created my own one which tries to add additional layers like direct. This however does not work.
The help file states this:
Selects layers processed by this imager with a glob or operator expression. An imager can use a selection to determine what nodes will be selected to be processed by the imager at render time. The selection is an expression that can consist of multiple selections concatenated by:
  • or (union)
  • and (intersection)
  • not (negation)
  • and not (exclusion)
  • () for nested scoping
So I have tried both * and "RGBA and direct" in the layers windows but without success. I actually dont know what layers refers to I just assumed it was AOV's but thats just guessing from the fact that RGBA is a AOV and it is in there by default.
Anyone who can shed any light on this would be greatly appreciated. We are in dire need of rendering with denosed AOVs.
8 REPLIES 8
Message 2 of 9
That's a known issue:
Layer selection does not work with Intel Denoiser · Issue #1498 · Autodesk/arnold-usd · GitHub
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
Hi Stephen,
Thanks for reply. It seems that was a known issue in Apr 20, 2023. Thats over a year ago. Either way can I use any of the other denoisers like noice in solaris? Is there any documentation on how to get that to work? I have not found it for Solaris.
Message 4 of 9
@mattiasTQTV7 wrote:
Hi Stephen,
They are all just imagers, so I think they will have the same problem.
But, to use them, you just create an imager and connect it via the Render Settings.
I was just about to do some testing, so the above is "off the top of my head"
// Stephen Blair
Message 5 of 9
Hmm, I tried doing that . I create a material library node. A arnold image builder. Inside I connected an oidn denoiser. I then dropped an arnold render settings node and went to shaders->imagers and linked it there. Nothing happened. Tried an exposure as well without result.
Basically I followed these instructions.
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_houdini_solaris_ah_Imagers_Stage_html
Is it possible to confirm this is working? Am I just missing something here.
Message 6 of 9
Sure, it works.
  • In a Material Library, add an Arnold Imager Builder.
  • In the Arnold Imager Builder, create a denoiser imager. I did an Optix imager.
  • I had other materials in the Material Library, so I had to increase the number of materials and set the Material VOP to the denoiser imager. Then I could see it in the Scene Graph.
  • In the Arnold Render Settings, go to the Shaders tab and set the Imager to the imager builder.
Same problem with Optix as OIDN though. It's just the RGBA.
Unless I use sick, then the additional layers are also denoised.
// Stephen Blair
Message 7 of 9
Thanks Stephen, yeah got it to work now but as you said only for RGBA. How do I render with this sick thing? I can se the manual saying "A command called "sick" can be used to replace the Solaris default "husk" that is used to render Hydra scenes." but I cant seem to find where I should put this in?
Message 8 of 9
Sorry, I should say "Direct USD Render"
That's on the Arnold tab of the USD Render ROP.
BTW, it seems that the problem has been fixed in the USD repository.
https://github.com/Autodesk/arnold-usd/issues/2084
I just don't know when that will be released. Maybe next update, or if not, the one after that.
// Stephen Blair
Message 9 of 9
Ok got it to work for now with the USD direct render. Good to hear that this will be fixed shortly as well. Thanks for your help today!
