Denoise aov's using oidn in solaris
mattiasTQTV7
Message 1 of 13
mattiasTQTV7
How do we go about denoising aovs in Solaris. Im using the default Arnold rendernode setup that creates an oidn shader in /materials/default_arnold_imager. In the Layers of that one I can see RGBA and its the only pass that is getting denoised. I created my own one which tries to add additional layers like direct. This however does not work.
The help file states this:
Selects layers processed by this imager with a glob or operator expression. An imager can use a selection to determine what nodes will be selected to be processed by the imager at render time. The selection is an expression that can consist of multiple selections concatenated by:
  • or (union)
  • and (intersection)
  • not (negation)
  • and not (exclusion)
  • () for nested scoping
So I have tried both * and "RGBA and direct" in the layers windows but without success. I actually dont know what layers refers to I just assumed it was AOV's but thats just guessing from the fact that RGBA is a AOV and it is in there by default.
Anyone who can shed any light on this would be greatly appreciated. We are in dire need of rendering with denosed AOVs.
Replies (12)
Message 2 of 13
Stephen.Blair
That's a known issue:
Layer selection does not work with Intel Denoiser · Issue #1498 · Autodesk/arnold-usd · GitHub
// Stephen Blair
// Arnold Renderer Support
Message 3 of 13
mattiasTQTV7
Hi Stephen,
Thanks for reply. It seems that was a known issue in Apr 20, 2023. Thats over a year ago. Either way can I use any of the other denoisers like noice in solaris? Is there any documentation on how to get that to work? I have not found it for Solaris.
Message 4 of 13
Stephen.Blair
@mattiasTQTV7 wrote:
Hi Stephen,
They are all just imagers, so I think they will have the same problem.
But, to use them, you just create an imager and connect it via the Render Settings.
I was just about to do some testing, so the above is "off the top of my head"
// Stephen Blair
Message 5 of 13
mattiasTQTV7
Hmm, I tried doing that . I create a material library node. A arnold image builder. Inside I connected an oidn denoiser. I then dropped an arnold render settings node and went to shaders->imagers and linked it there. Nothing happened. Tried an exposure as well without result.
Basically I followed these instructions.
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_houdini_solaris_ah_Imagers_Stage_html
Is it possible to confirm this is working? Am I just missing something here.
Message 6 of 13
Stephen.Blair
Sure, it works.
  • In a Material Library, add an Arnold Imager Builder.
  • In the Arnold Imager Builder, create a denoiser imager. I did an Optix imager.
  • I had other materials in the Material Library, so I had to increase the number of materials and set the Material VOP to the denoiser imager. Then I could see it in the Scene Graph.
  • In the Arnold Render Settings, go to the Shaders tab and set the Imager to the imager builder.
Same problem with Optix as OIDN though. It's just the RGBA.
Unless I use sick, then the additional layers are also denoised.
// Stephen Blair
Message 7 of 13
mattiasTQTV7
Thanks Stephen, yeah got it to work now but as you said only for RGBA. How do I render with this sick thing? I can se the manual saying "A command called "sick" can be used to replace the Solaris default "husk" that is used to render Hydra scenes." but I cant seem to find where I should put this in?
Message 8 of 13
Stephen.Blair
Sorry, I should say "Direct USD Render"
That's on the Arnold tab of the USD Render ROP.
BTW, it seems that the problem has been fixed in the USD repository.
https://github.com/Autodesk/arnold-usd/issues/2084
I just don't know when that will be released. Maybe next update, or if not, the one after that.
// Stephen Blair
Message 9 of 13
mattiasTQTV7
Ok got it to work for now with the USD direct render. Good to hear that this will be fixed shortly as well. Thanks for your help today!
Message 10 of 13
skeydzh
Hey! is there any update on this? looks like its still not working
Message 11 of 13
2309527867
Hello, I’d like to ask whether denoising can now be applied to AOVs.
If that’s possible, could you teach me how to do it?
Message 12 of 13
Stephen.Blair
It's working for me with the latest HtoA. Probably been working for awhile, I haven't tested it for awhile until yesterday.
I've attached my test scene.
Because it's for testing, I'm not using the default denoiser imager that HtoA created. I'm using one I created in my MaterialLibrary.
I've also used the Output Suffix, so I added two custom AOVs named RGBA_denoised and direct_denoised.
// Stephen Blair
Message 13 of 13
2309527867
@Stephen.Blair Thank you. While using OIDN, I’ve found the results to be very unpredictable. I increased the samples, but it had no effect on the denoising result. With AA 2 and AA 8, the RGBA denoising result is exactly the same. How can I achieve better denoising results?
