Arnold for Houdini Forum
Rendering with Arnold in Houdini and Solaris using the HtoA plug-in.
Arnold 7 cannot read usd primvars for instanced geo in htoa/mtoa
3 REPLIES 3
dlekanis
328 Views, 3 Replies
Is there anyone that has the same issue?
Describe the bug
I am testing a layout setup inside Solaris, where I generate per instance geo primvars to control shading variations.
While everything works fine inside Houdini Hydra with Arnold, and the shading variations work fine, when rendering the cached usd file with a standin, either in htoa or mtoa, the primvars are not being picked up and the shading variation doesn't work.
Replicate the bug
  • bring multiple copies of the same packed primitive, with different integer index attibutes, inside Solaris and apply a shader with where we color jitter the diffuse Color using the index attribute inside a user_data_int
  • Test if it works inside Solaris
  • Save the Usd, and try to render it from a procedural, checking if the shading variations get picked up
  • In the packed primitive option of Sop import/sop create, change to xforms or unpack, save as a different version and test if the error exists for this one too
Expected Behaviour
Expected the result from the Arnold procedural to give me the same shading variation as when rendered inside Solaris.
Screenshots
image.pngRender inside Solarisimage-1.pngRender from Arnold Procedural
Used Software Versions
  • Arnold 7.0.0.3
  • Htoa 6.0.2.2
  • Houdini 19.0.531
  • OS: centos 7
  • USD Version: 21.08
File:
testUsdPrimvars.zip
Tags (4)
Labels (4)
3 REPLIES 3
Stephen.Blair
in reply to: dlekanis
@ Can you post your test scene please?
// Stephen Blair
// Arnold Renderer Support
dlekanis
in reply to: Stephen.Blair
Added it in the main description
Stephen.Blair
The second usd file doesn't work at all with the procedural. I get
00:00:03   190MB ERROR   |      [usd] Failed to open file ()
00:00:03   190MB WARNING |      [ginstance] /torus2/torus_0002: trying to clone a NULL object
00:00:03   191MB WARNING |      [ginstance] /torus2/torus_0001: trying to clone a NULL object
00:00:03   191MB WARNING |      [ginstance] /torus2/torus_0000: trying to clone a NULL object
And if I write out the usd files again, neither of them works ("Failed to open file" )
// Stephen Blair
