Arnold 7 cannot read usd primvars for instanced geo in htoa/mtoa
- Mute
- Permalink
- Report
Is there anyone that has the same issue?
Describe the bug
I am testing a layout setup inside Solaris, where I generate per instance geo primvars to control shading variations.
While everything works fine inside Houdini Hydra with Arnold, and the shading variations work fine, when rendering the cached usd file with a standin, either in htoa or mtoa, the primvars are not being picked up and the shading variation doesn't work.
Replicate the bug
- bring multiple copies of the same packed primitive, with different integer index attibutes, inside Solaris and apply a shader with where we color jitter the diffuse Color using the index attribute inside a user_data_int
- Test if it works inside Solaris
- Save the Usd, and try to render it from a procedural, checking if the shading variations get picked up
- In the packed primitive option of Sop import/sop create, change to xforms or unpack, save as a different version and test if the error exists for this one too
Expected Behaviour
Expected the result from the Arnold procedural to give me the same shading variation as when rendered inside Solaris.
Screenshots
Render inside SolarisRender from Arnold Procedural
Used Software Versions
- Arnold 7.0.0.3
- Htoa 6.0.2.2
- Houdini 19.0.531
- OS: centos 7
- USD Version: 21.08
File:
Link copied
