Unable to select uv Coord Space
mattiacg2020
mattiacg2020
Community Visitor
Community Visitor
I'm trying to use a camera projection node in my shader but i cannot select "uv" in the coord space field as described in the documentation here. I'm using a simple texture node for the projection color input and then i'm using the result of the camera projection in a ramp_rgb.
Do i need to do something else to have the option available?
I'm using C4DtoA 3.0.3.1 with C4D R21 on macOS 10.14.6
Stephen.Blair
There is no uv option for coord space, the docs have to be updated.
// Stephen Blair
// Arnold Renderer Support
mattiacg2020
Community Visitor
Community Visitor
Thanks for the reply, is it possible to achieve the same result without the option there?
