Toon Shader - Volumes
Hi. I am currently working on a project and want to use Toon Shader. I need some volumetrics in some scenes like VDB clouds and explosions. Is there a way to use volumes with Toon Shader?
Stephen.Blair
Sorry, but no.
https://docs.arnoldrenderer.com/x/ppvhAw
Volumes, motion blur, DOF and the VR camera do not currently work with the Toon shader.
// Stephen Blair
// Arnold Renderer Support
diego6S3FN
Hopefully soon compatible with VR camera.
madsd
Depending on the host, I am not a c4d person at all.
But technically, you can "mesh" an explosion with a volume_to_mesh construct.
The meshed Explosion files will work with the toon shader.
You can look into Houdini, or Bifrost if c4d does not have such a workflow ready.
Its not really Arnold issue, its more like a general tool/trick to do the conversion that is needed I think. ( then Arnold dev also dont need to do this render time by converting the vdb to mesh based on some switch some place )
lamarKPDHG
Just coming across this problem now and wondering if there's some way to trick this effect in compositing? Like render a volume aov and then composite that in After Effects?
