Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Tri-Planar Feature Request
2 REPLIES 2
mckenzie2VER2
238 Views, 2 Replies
mckenzie2VER2
Can you change the default color swatches on the tri-planar node to default to RGB colors when using separate axis? Right now they are just white, so you have to change the color to check which axis is where. Works this way on Redshift and super handy ๐Ÿ™‚
2 REPLIES 2
peter_horvath
Sure, makes sense. I'll add it to a future release, thanks.
// Peter Horvath
// C4DtoA developer
// Peter Horvath
// C4DtoA developer
mckenzie2VER2
Much appreciated!
Much appreciated!
