Can you change the default color swatches on the tri-planar node to default to RGB colors when using separate axis? Right now they are just white, so you have to change the color to check which axis is where. Works this way on Redshift and super handy ๐
Solved by peter_horvath. Go to Solution.
Sure, makes sense. I'll add it to a future release, thanks.
Much appreciated!
