Render Mask only
Render Mask only
simonEPZ3S
Message 1 of 8
Render Mask only
simonEPZ3S
Is there a way to render only masks?
I have a scene with lots of objects and sometimes I get into photoshop and realise that I am in need of an extra mask. I go back to C4D and add an Arnold Object Mask to the object and then re render but it seems to always render the beauty so it takes a long time when all I need is the mask.
I guess I am looking for a check box in the render settings that says "render masks only". Does this exist?
Or is there another way that I am missing?
Any guidance appreciated. Thanks.
Replies (7)
Message 2 of 8
Stephen.Blair
Try clearing the AOV checkbox
// Stephen Blair
// Arnold Renderer Support
Message 3 of 8
Eden_Soto2
Wouldn't outputting a Cryptomatte be an option as well? This way you can select any object in the scene without any re-rendering at all
Message 4 of 8
peter.horvath6V6K3
Currently beauty is always rendered in the Picture Viewer, even if you disable the AOV on the display driver. I see that rendering only specific AOVs without the beauty could be useful, so I try to add this to a future release.
The IPR renders only the selected AOV by default (without the beauty pass) if 'Render all AOVs' is turned off, so that could be a workaround for now?
Message 5 of 8
peter.horvath6V6K3
Right, I guess using cryptomatte could be an option as well.
Message 6 of 8
Stephen.Blair
If I use Render Queue, it renders without the beauty
C4DtoA | 00:00:01   731MB         |  render done in 0:01.583
C4DtoA | 00:00:01   731MB         |  [driver_exr] writing file `S:\Projects\c4d\output_diffuse.exr'
C4DtoA | 00:00:01   732MB         |  [driver_exr] writing file `S:\Projects\c4d\output_specular.exr'
C4DtoA | 00:00:01   671MB         | render done
// Stephen Blair
Message 7 of 8
simonEPZ3S
sorry for the delay...i got side tracked.
Not used Cryptomatte before but just had a quick play and I think that could work for me.
Thanks!
Message 8 of 8
simonEPZ3S
I tried this and that worked for me as a workaround.
