When loading an Alembic particle cache using C4D's native Particle Geometry I can assign an Arnold Tag and give the particles custom geometry, radius, variation, etc. Can't find a way to do the same when loading the same .abc into an Arnold Procedural. Tried an Arnold Scatter and custom settings in an Arnold Tag.
X-Particles doesn't pass rotation data to Thinking Particles so it can't be baked into an alembic file.
Edit : Didn't realize Arnold Scene Export could recognize X-Particle caches directly. Importing that .ass sequence in and applying an Arnold Tag set to Points worked. Was previously using the XP-to-TP-to-ABC route which strips the cache of anything but position. Still can't figure out how to get custom shapes on that using the Procedural / ABC method.
Edit 2: I was mistaken. It was inheriting the shape set in the XP Emitter's Display tab. Still can't assign custom shapes to .ass sequence particle cache.
Solved by peter.horvath6V6K3. Go to Solution.
It's not possible unfortunately. Instancing with a custom shape is done by the plugin in export time on a particle system which exists in the scene. A procedural is a black box in that sense.
You can use an operator to change the mode on the points node within the procedural to render spheres, but no custom geometry.
