- Mute
- Permalink
- Report
When loading an Alembic particle cache using C4D's native Particle Geometry I can assign an Arnold Tag and give the particles custom geometry, radius, variation, etc. Can't find a way to do the same when loading the same .abc into an Arnold Procedural. Tried an Arnold Scatter and custom settings in an Arnold Tag.
X-Particles doesn't pass rotation data to Thinking Particles so it can't be baked into an alembic file.
Edit : Didn't realize Arnold Scene Export could recognize X-Particle caches directly. Importing that .ass sequence in and applying an Arnold Tag set to Points worked. Was previously using the XP-to-TP-to-ABC route which strips the cache of anything but position. Still can't figure out how to get custom shapes on that using the Procedural / ABC method.
Edit 2: I was mistaken. It was inheriting the shape set in the XP Emitter's Display tab. Still can't assign custom shapes to .ass sequence particle cache.
