C4D GPU performance discrepancy between 2 CPUs
P_Deb
P_Deb
I'm testing C4DtoA GPU performance on 2 different cpus and have noticed a marked performance difference, hoping someone can shed some light.
cpu1 (desktop): Threadripper 1920 12-core with a GTX 1080, 64GB RAM, Win10
cpu2 (laptop): Ryzen 9 5900HS 8-core with a RTX 3070, 16GB RAM, Win10
C4DtoA CPU performance is almost identical (Threadripper with a slight edge), but when I switch to GPU, the laptop blows away the desktop by an almost 5:1 speed margin, which is odd as GPU benchmarks give the 1080 the edge.
Task manager shows GPUs spiking to 100% during test renders, so is it a matter of the GTX 1080 just not meant to perform well with C4DtoA GPU?
thanks in advance
thiago.ize
I think 3070 should be way faster than a gtx 1080 at ray tracing, especially since it has dedicated ray tracing hardware which 1080 does not.
P_Deb
thanks Thiago, appreciate the reply.
would a lack of dedicated hw raytracing typically explain a 5x speed difference, or should I be looking around for a tweak to my GPU settings?
thanks, P
nwoolridge
The 1080 is much older and much less capable than the 3070, so a performance delta of that magnitude would be expected. See here for an example (scroll down to the GPU benchmarks). Other factors could include included VRAM, scene complexity, and system architecture...
